The Giveaway Thread
Okay this is for amateur and pro DIYers. This is a Teac MC-DX220i micro hi-fi system (CD, iPod, Radio, Aux) - of course dismantled by me for "educational" purposes :). What is missing are two Satellite drivers and one subwoofer driver and their cabinets. The original ones were damaged long ago. But i have used many different small satellites with it. All the electronics and proprietary connectors are there. And it definitely works. You need to do three things - 1. Make two small satellites (10W 4ohm). I have used 3" peerless drivers and it works perfectly. 2. Make a small subwoofer with a 5 or 5.5" driver (15-20W, 8ohm). Again a peerless SKO130 or MH13 should work great., 3. Reassemble the plate amp and mount it behind the sub. OR. You could convert it into a 2.1 single box with the plate amp at the back. The sleek table top system connects to the plate amp with a single multi pin wire. It draws power from that too. Let me know if it interests anyone.
This is also still available.
Got the following to give away...
1. Garrard SP25 MkIII Got it, tested the motor but never got around servicing it
2. CNC Phono Kit Got it from Sachin but never got around building it
3. Sony Playstation One (SCPH-5552) with the famous AKM DAC. I got it to do the CDP duties. With a basic cleanup of the optical unit, I was getting amazingly low noise floor but a constricted soundstage. I guess the main issue is since it does not have the native RCA out but is converted using an outboard adapter. If you are savvy enough to fiddle with the converter and put better power supply and caps, you could have a killer CDP.
4. 2 Discman (or is it Discmen?) 1 is working fine, needs a bit of cleaning, the other not so working, can be salvaged for parts or maybe you can make it work
5. Givson Bass Guitar do notice the v in the name. Strings changed recently but not really played regularly
These will necessarily have to be picked up from my place. I got a few stuff on sale as well, in case you are picking up something there for shipping, I could try to bundle these along...
Might have a few more things later...
Wow! such a nice give away. I want to be greedy and ask for everything; I would like to put myself in queue for 1, 3 & 5 :)
I can pick Sony play station if available. Guitar, if not taken. I'm looking to buy stereo system with USB to play mp3. Is it available in your items for sale
sent you a pm a while ago from tapatalk for the garrard, not sure if you got it or not as your message box looks full.
Turntable & phono kit blocked for a fellow member/old friend who called first...
Bass Guitar blocked for jmascreen followed by canchi, swaroopks and 007india
Playstation blocked for swaroopks followed by 007india
I'll let you guys talk it out on who gets what, please confirm your pickup as well...
Hi Doors, I did get your first message (not sure if you sent more later) but I was out for a bit, in the meantime an old time member and friend called up to confirm his stake on the TT and phono kit, you are next in line if he opts out...
Can you PM me your location?
Is this still available?
@soulforged
Can I have the working discman? If no one else is in line
