DesiAudiophile
IA with DAC is not cheap; but many come with headphone jack
I researched some online, can you tell me please name some of IAC's with DAC & Headphone output ?
DA
This is a beginner question so dont get me wrong.Just for time being, I gonna use only my jogging headphone Sennheiser px-80 headphone as output and use an int. amp with inbuilt DAC and then think of a bookshelf speaker.Is there an Integrated amp that has inbuilt DAC with headphone output 3.5mm jack so i can connect my headphone with it ?
DA
DA
Hmmm ...
Digital music equipment curve is advancing faster than analog components.
So look for bargains in analog IAs. People are always upgrading their entry level setups and you will find some good equipment on the forum or outside.
There is a Yamaha A-S500 for sale from Chennai itself; definitely worth a look and listen.
Get a simple IA, maybe add a simple DAC and the buy a set of speakers.
You can lug your amp for speaker shopping.
Raghu
FLAC/ALAC/MP3/etc are archival formats not recording formats.
If you rip CDs that are distributed in 16/44.1 into 24/96 FLAC you are simply bloating the file with useless information.
Yes there are hi res download sites that one can pay a premium and buy music.
If you are the kind to do torrent D/Ls how are you sure it is studio quality? I have heard 24/96 recorded from vinyl, allegedly, that sound like crap; see what I am getting at?
If you are paying premium for hi res music, stop for a while and divert the funds towards music equipment and then restart purchases towards your hi res collection.
For recording purpose you need 24 bits and higher sampling rates. The sound engineer has some leeway to fiddle around during the mixing stage.
For playback, 16/44.1 is good enough. FLAC/ALAC/other lossless formats are required to preserve the information in case you want to cut a CD again.
MP3s will have already lost the info during trans-coding/ripping.
FB2K on laptop can decode 16/44.1 or 24/96 or 24/192 and eventually push it to the onboard DAC (realtek as you claim) or via USB to an outboard DAC/Amp.If going head-fi route, look at USB DACs or DAC/Amps from SMSL/FiiO/Schiit/AudioQuest, to name a few.
If you can plan your purchase, look for a pre-out from outboard DAC for future integration into an active desktop system or conventional 2-ch system.
Fix your budget first. This will dictate your wiggle room.
Raghu
If you plan to go head-fi, I would recommend against ATH-M50X, I have ATH-M50 and sound signature is similar for both the headphones. No doubt its a good headphone but it is heavy on bass side and price is inflated in india, there are better headphones available. Senn HD598 is good entry level headphone with amazing soundstage and clarity, and it keeps coming on sale on amazon.in for 7-8k, keep a lookout for that.
Other way would be to go for an IEM if you are comfortable with those. For starters Hifiman RE-400 is one option which is regarded neutral and highly revealing so it will also give you an idea about recording. It normally sells for 5k.
Disclaimer: I own above 3 and I prefer HD598 but looking for an upgrade now.![]()
The best option is to buy an o2 odac combo with sennheiser 5xx series dynamic headphones.
Norge is good but instead of the Boston try the elac b5.later you can try DIY amps for less than 10000 bucks with much better sound quality.
Used kits like the yamaha s100 on the forum is also good.
Within a few posts your budget went from 20K to 30K. Quicksand dude! Fix the budget.
Raghu
Also look at ATH-M50. Similar price range to Senn 558.
I researched about these products too but personally think beyerdynamic dt 770 pro is better because i want closed headphones for noise isolation but the 10 meter cable length is a downside. Also im thinking about how the aftersales support will be with beyerdynamic dt 770 pro. Need ur opinion
DA
I have had the DT990 for more than 8years now and it's good . Dt770 is very good and if possible do try the DT880 as well based on you budget . I am not sure if you need after sales as long as you get warranty to take care of any defect .
The long cable is really not an issue . If you are brave enough you can do a minor surgery and upgrade the cables in a future date as well
Hello, thank you for the reply. well, what would you do if you want to change the ear - cups or having to repair the headphone. I'm from chennai and i saw a beyerdynamic dt 770 dealer in bangalore only. How long is the warranty ? and if any case of problem, can i post send the headphones to the dealer in bangalore and will they repair and post-send to me back ? (I dunno how much to trust them).
