Yes.. it does come with single RCA to 2 RCA cable, though short.. abt 5 feet i guess..
5ft is fine with me as long as its good quality cable
Cheers.
are the spikes removable in the sw10? would prefer no spikes. Cheers.
I didn't check them.. Don't think they are removable.. You can use a simple door mat below the sub to avoid the spikes contact with the floor..
you happy with the sub now? you been having it for a while
Cheers.
Yes.. Very much..
no humming issue with your second SW10?
there was another FM who had the same issue like you, he got it fixed by changing the capacitor,i was about to buy this sub & now in 2 minds, you think its a batch issue or a defect?
should i still gamble & buy one? Thanks.
Yes.. Aware of that.. Mostly it looks like a batch issue..
If you like the sub, find a dealer in your city, check the sub and then pick it up..
so the humming sound comes out of the box? i thought it comes after few hrs of use.Thanks.
Nope.. Not for me.. But it developed over time.. I got them in Oct-Nov'16
ok, taking the gamble, this sub comes with a y cable right? so its recommended to connect it with a y cable? Thanks.
Yes.. Very much..
is it good for music listening?
My budget is 30k...REL subs are for music, but costlier. What is your budget?
I listen to stereo in 2.2, and i can say it is much better than what i have heard in 2.0..is it good for music listening?
My budget is 30k...
REL T Zero can be got for 35k post discount, where are you located?
Cochin, kerala
And this 6.5 inch woofer can deliver same punch as 12 or 10 inch?
