sudhirbhosale
Hi all
I bought 3" full range driver for some project. Giving very sweet sound especially at high, as diameter is 3". Little bright also but listening experience is good. Sound was very sweet. I just put in wooden box and connected to 15 watt DIY amp.
I have floor standing speakers with peerless TL26SG tweeter. That gives flat response I am planning to replace.
So one idea I am thinking. If I use small full range which I liked, in my 2way speaker to replace tweeter , then no need to use cross over as it support full range but higher frequencies. And woofer is mid-bass (peerless S16NI) having freq response supported to wider range i.e. 80-5K .
Logic: Mid bass would deliver low-mid frequency but weak in higher side. Small full range driver would deliver wide range of frequency but strong in higher side. There would be overlap of wide range, so no single specific point where sound around crossover region change its path i.e. some from tweeter and some from woofer. (however crossover of 3Khz ensure that all vocals are managed by one driver)
Reason for doing this :
Current tweeter is not satisfactory
Avoiding Cross over - So minimum processing components
Challenges would be,
The Power handling capacity is low for small full range driver - Can be controlled by adding resistor
Some frequencies coming from both drivers may have higher levels.
Pl note : I do not have any instrument to measure SPL or entire response
hence would judge by ears only.
Would like to know thoughts suggestions or any expert comments from FM. If anyone know such kind of design. Any pros-cons of this approach.
