please help me to buy a 7.2 AVR in US. I added my choice
Naveenbnc
Hyderabad
Hello All,
Please help me buy a 7.2 AVR in US under $600.
My requirement is 5.2.2 Dolby atmos & Lossless music play with usb.
60% movies and 40% music
I found Denon AVR-X3300W is the only one with 7.2 preouts under $600
Is it a good pick?
https://www.amazon.com/Denon-AVR-X3...d=1511864415&sr=8-1&keywords=denon+avr+x3300w
(please suggest any better alternative under 600$)
Secondary options at half the price ($300) are:
Denon AVR-X1300W &
Yamaha RX-V681BL (amazon best seller, but not sure if it plays lossless music)
These two models don't have all the bells and wistles, They are very quite cheap, but still I get 7.2 Atmos. (I can allot some budget for camera etc)
3rd option is, refurbished AVRs from accessories4less.
I get better models under $300. See the link below and please suggest if any one is a good VFM to buy.
https://www.accessories4less.com/ma...home-theater-receivers/1.html?number_channels
https://www.accessories4less.com/ma...ch-x-105-watts-networking-a/v-receiver/1.html
https://www.accessories4less.com/ma...ch-x-100-watts-networking-a/v-receiver/1.html
If my above plan is not good, please ignore and kindly suggest a good choice under $600
Secondly, please suggest if I have to pay any customs if I bring it in my checkin luggage
Thanks a lot in advance:)
Naveen
If you repack the Amp it doesn't require any customs.
I took Denon x3100 from US of 110v, it's working fine with converter from Maxine.(approx &
?3500)
#No problem with customs if repacked
All the best.
Thanks a lot for all of you...
As far as I know, Aventage is a high end series in Yamaha.
Denon-X3300W has more bells & wistles, and it has 7.2 pre-outs, and we can build a really powerful system by adding power amps in future.
How ever....Talking only about the audio quality, does the Yamaha AVENTAGE RX-A770BL perform better than Denon -X3300W?
my personal preference would be denon since you would be using it more for movies. the 4300 would be good for both movies and music
I heard another model in AVENTAGE (2030) series.I liked the quality.
As per your budget wise I suggested that 770BL.
Don't have any experience with Denon 3xxx or 4xxx series so no comparison.
May be Yamaha uses a specific DAC on Aventage series.. Other brands also use equally competent one..
Don't think you will need a power amplifier for <200 Sqft room, assuming you use efficient speakers..
May be hard to distinguish between the two in terms of sound signature.. But, don't give due weight-age for this factor alone..
