MJ23Bulls
Won't the AVR's room correction s/w pick it up and suggest you the remedy?Ok.. Good one.. I have already used double layer of spandex over the frame and the center channel speaker is abt 2 inches behind the screen.. If i add an other layer behind the frame, sure it would look good, but it may affect the sound from center channel...
My suggestion would be along the brick wall, without disturbing the flooring. Anyways, you know your room better than me.The electrical wiring is something that we can hide using casing, but the speakers wires are very difficult to hide in a Tiled floor, brick wall.. Sure, i will check for bigger casing material..
I have abt 5 cables running behind the screen from left to right, and they are thick as well.. Gypsum walls would have been easier to do all these...
What I mean is that when you flip up the screen itself, you might be able to feel how the left & right corners of the tip of the screen start moving on their own. It's a huge screen, indeen. So the hooks I'm talking about need not be on the tip (near the ceiling); but somewhere near halfway mark or better somewhere between 1/2 and 2/3 mark.When the screen is flipped up, the tip of the screen is abt 9'7" off the floor.. Just kissing the ceiling.. Hooks near the tip is fine, but accessing them will be a challenge..
And by the way, looks like I should plan a visit to your place
