The Giveaway Thread
Have a pair of Polk audio Speakers They are from the HTMS
Model number is : RM6751
Just let me know why you want it and if the message is genuine its yours,
The speaker is located in Mumbai
Speaker specs
EnclosureBass Reflex
Video ShieldedYes
Tweeter TypeSemi-domeTweeter
Size (inches)0.5
Midrange Size (inches)N/AWoofer Size (inches)3.5
Woofer CompositionPolymer composite
Woofer SurroundFoam
Power Range20-100
Sensitivity89 @2.83Vrms dB
Impedance (Ohms)8
Frequency ResponseN/A
Connector TypeSpring Clip
Bi-amp InputsNo
Height (inches)6-9/16
Width (inches)4-1/8
Depth (inches)5-1/8
Weight (pounds)2
Speaker specs
Video ShieldedYes
Size (inches)0.5
Woofer SurroundFoam
Power Range20-100
Impedance (Ohms)8
Bi-amp InputsNo
Width (inches)4-1/8
Depth (inches)5-1/8
Weight (pounds)2
Nishant here, I would like to use them for my HT. It's 5.1 at present and would love to make it 7.1.
Nishant
Speaker specs
Video ShieldedYes
Size (inches)0.5
Woofer SurroundFoam
Power Range20-100
Impedance (Ohms)8
Bi-amp InputsNo
Width (inches)4-1/8
Depth (inches)5-1/8
Weight (pounds)2
I have a Philips 5.1 HT, a good in itself But a better fronts will improve the output dramatically.
Hello Nishant whats the rest of your setup and how will these be a value add.
I have a Canton speakers. I couldn't find matching sattelite for surround. Just saw they might be a good try to see if it's matching.
Nishant
Hi Kane,
I've all the Polk setup just because Ioved the way Polk sound and my last OLX purchase was RTi A1 to match my RTi A3. I pulled my setup from my bedroom and now need a pair of polks for a stereo, I may use them with small class D amp :) This was just my reason.
Thank you!!
I have messaged a couple of FM, If it doesnt work out with them then will handover to the next. Until that time consider these as given away.
One more give away :)
This one albeit is a non working one, it powers up but that's about it not the greatest of condition so as is
Make denon
Model AVR 1911
You can collect it from me and repair it or scavenge for parts
Locations is Mumbai : Vikhroli West -LBS Road Hometown Building
Speaker specs
Video ShieldedYes
Size (inches)0.5
Woofer SurroundFoam
Power Range20-100
Impedance (Ohms)8
Bi-amp InputsNo
Width (inches)4-1/8
Depth (inches)5-1/8
Weight (pounds)2
Hi, Im looking for a speaker pair to connect to my DVD player that also has USB input to play MP3. Please let me know if its still available.
Make denon
Model AVR 1911
Hi, If it powers UP and MP3 playback via USB port works, then I can take it. If not, please PM on how to get it working.
These have already been picked up last week. thanks to all that showed interest.
Make denon
Model AVR 1911
THis has been kept aside for a FM, once i sort out logistics will ship to that FM.
Watch this space for the next few days will put up more giveaways. hope they find home where they will be put to use. in the list are a couple of center speakers and speakers of around 16ohms
Nice. I could use the center speaker as they should match with my Sony bookshelf speakers I already have. But wouldn't require the bookshelf speakers. If possible I would like to get just the center speaker.
sure i think the single one was from a 7.1 system these were the surround rear, i cant seem to find the specific center ones, but if you want to give it a try i could send them to you. i have a couple center speakers as well i will put them up as give away in a day, maybe you want to take a look at them. one is a polk ( from the same set i had put earlier)the other are denon if i am not mistaken. give me a day to hunt them out
Sure will wait for you to update the thread. I guess this Sony or polk would work for me.
