Hello FM's
I got my Marantz SR6012 from HTstore Bangalore this weekend.
Noticed few things on new AVR, thought of updating you guys in case if this helps someone.
You can select the speaker impedance - 4ohm to 8 ohm and the AVR supports upto 16 ohm speakers
http://us.marantz.com/DocumentMaster/US/mz_SR6012_om_u_en_v00.pdf --- Page 37
Use speakers with an impedance of 4 – 16 Ω/ohms.
Carry out the following settings when using a speaker with an impedance of 4 – 6 Ω/ohms.
1. Press and hold the main unit’s ZONE2 SOURCE and STATUS at the same
time for at least 3 seconds.
“Video Format < NTSC>” appears on the display.
2. Press DIMMER on the main unit three times.
“Sp.Imp. <8ohms>” appears on the display.
3. Press TUNER PRESET CH + or TUNER PRESET CH- on the main unit to select the impedance.
8ohms(Default) :
Select when the impedance for all of the
connected speakers is 8 Ω/ohms or over.
6ohms:
Select when the impedance for any of the
connected speakers is 6 Ω/ohms.
4ohms:
connected speakers is 4 Ω/ohms.
4. Press the main unit’s STATUS to complete the setting
Mine is Dali Zensor 7 and it is 6 Ohm speakers
Audyssey even force you to adjust the Sub woofer volume to below 75dB before running the calibration
Overall build quality and materials are better than previous SR6008
8ohms(Default) :
6ohms:
4ohms:
