My Home Theater Hunt....
Hi everyone... Have taken Yamaha rx v 583...have fitted dolby atmos as overhead speakers.Have checked all the connections, but some how one surround speaker and the overhead speakers are not giving any test tone... Can somebody suggest anything.. Thanks...
1. First check if the speakers are ok ,since your front channel are working connect to it and check.
2. kindly see that your are playing dolby atmos tracks/surround 5.1 or 7.1 channel recording.
3. Finally check the avr settings see whether it can decode atmos tracks and also the amp section of your avr ,check if you are getting output for surround and atmos connections.
rajesh
Is Wharfedale Diamond 220 ok? will it match with my Yamaha V585?
Can't stretch my budget so Wharfedale Diamond 225 is a no.
How is Boston Acoustics A 26 (16K - Amazon) compare to Wharfedale Diamond 220.
Confuse between these two. Which will be a better choice for movies and music both (50:50)
@Krishroy2004
The Bose 201s will belt out decent bass...6.5 inch drivers....please note...these speakers are quite placement specific.....
The 220s will not belt out much bass....i would prefer the 225 or the Bostons for sure....
See this link.....
https://www.ooberpad.com/collections/bookshelf-speakers?sort_by=price-ascending
I would look at:
Polk RTiA1 / A3
Dali Spektor
Bostons A25/26
https://htstore.in/index.php?route=product/category&path=109_57_80&sort=p.price&order=ASC
JBL Arena 120s
Taga Azure B40
I would put my money in these babies for sure...(i own the S30s)
http://shop.technoguru.in/bookshelf...x50-bookshelf-speaker-pair-5055300407979.html
Decide accordingly...there would also be bookshelf speakers made by Yamaha too
@Krishroy2004
See this link.....
I would look at:
Polk RTiA1 / A3
Dali Spektor
Bostons A25/26
JBL Arena 120s
Taga Azure B40
Shortlisted Taga Azure B40 & Bostons A26, Which one is better?
Need one information....
My front speakers are rated 8 ohms and my center and surrounds are rated 6 ohms. Will there be any issue with this setup?
