My existing TT setup is Technics SL3200 with Shure M97XE. It picks up surface noise/ static pops quite easily on records that are not new or clean enough. I read several HFV threads and it seems using a less detailed cart can solve the problem like Shure M44-7. Is this correct understanding? I do not use the M97 with higher than 1.25 gm weight in fear of Wearing out records faster, also never tried the playback with brush down.
If separate cart is the ultimate convenient solution I simply cannot switch back and forth between them in the same TT. So want to check if there is a reliable way to mod my other Philips Hi-Q International TT (change its cart and also find it's pre-amp out to hook with my main system) or do I need to look for a separate TT. Budget can be max 30K plus cart.
Suggestions welcome
Suggestions welcome
