Yet another update to my phono journey. I finally got hold of the Nagaoka MP200 a month back. My first impression of the Nagaoka, was frankly quite bad. Compared to the Denon cart, that had a metallic finish and came rather nicely packaged, the Nagaoka with its purple plastic body look CHEAP. And this was a cartridge that costs a lot more than the Denon. Round one was comprehensively owned by the Denon.
Then came the installation. The Nagaoka is a comparatively large cartridge, Both in terms of the length and height. On my headshell it was quite a tight fit. Also since my TT does not have a VTA adjustment, the cart is barely above a 180gm vinyl. Not really an issue but need to be careful. On the plus side its boxy dimensions made alignment a bit easier. Round 2 also went to the Denon, but by a thin margin.
Then came the important test. I paired it with the Mani, set on MM mode and finally settled down to be blown away. And blown away I was, with the volume..I literally jumped at the volume knob, set at levels suitable for the Denon, and turned it down. I thought the gain on the Mani was set on level 3 but it wasn't. I set it to level 1 but the sound was simply rubbish. So back on level 2 I had to lower my amp volume to hear the cart.
At similar volume levels, my first impression was that the Nagaoka had a bigger sound. Compared to it, the Denon seemed laid back. I was not sure if I like it but it certainly suited acoustic music like Eric Clapton's unplugged. The instruments were clear, separated and distinct. But I perhaps that was due to the higher volume/gain. However one area which was distinct LG better was the bass, much deeper and well defined. As a result the sound seemed meatier than the Denon. I put on another favourite, Eric Clapton's Just one Night, a much busier live album but very well recorded. The biggest difference again was the bass. I thought this will only get better as it runs in.
My only problem was the volume gain. I could operate only in a very narrow band. Outside this band the sound either lacked any definition or was a bit shouty. But this was my initial impression. I continued playing it for a couple of weeks. I must say that the sound began growing on me but the volume issue kept bothering me.
The problem with comparing cartridges is that it is difficult to do a AB test unless you own another headshell, which I did not. So after a couple of weeks I switched back to the denon for yet another comparison. immediately I noticed that the sound was mellower and smoother. There was that laid back sound that I enjoy quite a bit. But the bass definition was gone. The sound was leaner and in my favourite tracks the bass guitar seemed to have been relegated to the back of the room.
However as I listened to the cart I again started enjoying it. After a week of the Denon I switched back to the Nagaoka and yet again started enjoying the bigger and well defined sound.
So while I am leaning towards the Nagaoka Mani combo the results are far from declaring a comprehensive winner.
In conclusion,
1. To my ears the Project phono box sounds better than the Schiit Mani in MC mode and vice versa in MM mode.
2. Nagaoka MP 200 and the Schiit Mani is a fantastic match. I simply love the quality of bass that this combo extracts from vinyls. In my system however there is an issue with the volume gain. I have actually ordered for a Schiit Sys (essentially a volume controller) which I hope will sort it out but let's see.
3. I wish there was another gain level on the Mani.
4. The Denon DL 301 mk2 is a beautiful sounding cartridge. Showed me what a cartridge upgrade can do to your analog hi-fi experience. I am pretty sure it can benefit from a phono stage upgrade.
5. Finally, you can be perfectly happy with you hi-fi set up if you do not compare. This game is both time consuming, nerve racking, confusing and expensive, but I have to admit, a lot of fun.
This I think concludes my system testing for the time being. But unfortunately now I keep getting drawn to TT reviews and to online hi-fi websites!! I must say I am quite smitten by the Mofi studiodeck and the Elac Miracord 70. I also find the Technics SL 1200 quite interesting and am toying with the idea of buying a pre owned one. Any suggestions would be appreciated
