Hello all,
I am planning on buying the Xtreamer and have a couple of noob questions - I'm hoping you can help resolve the following:
1) I have movies stored on my pc. Can i play them through Xtreamer
without having to copy them to an external hdd/ usb and then connect it to Xtreamer?
a) If yes, can i access movies/ folders/ my PC (literally!) directly from Xtreamer (using the remote control)? OR is that i need to open the movie on my PC and click PLAY and then wait for it to stream/ project on the LCD tv via Xtreamer.
Note: I'm using Windows XP SP3 as opposed to Windows Vista (if that helps)
2) Can i stream LIVE football matches/ television shows/ content that does not air in India, from the Internet using Xtreamer? I can do this directly on the pc, but nothing like a 42" experience !
a) If yes, can i do this directly from Xtreamer using the 'Net' option from the menu? OR do i need to go to my pc, type the URL and then wait for it to stream/ project on the LCD tv via Xtreamer
b) Do i need any additional software for this? Heard of something called TVersity but not sure if this is the correct use of it..
Would be great if i could get some confirmation/ comments..
Many Thanks.
Cheers!
@ Dushie - your posts above have been very helpful.. clarified a lot of other questions i had in mind
