How are making it Bro ??I have just started my journey, my first step towards turntable. Below is my completed drawing of Plinth for Lenco L-75. The Process has just started.
Sadik
I would suggest PTP. It's pretty simple.
very nice ! you seem to be using the PTP6. I am pretty sure the Naim Aro would be a fantastic combination with this !
One suggestion, wind some plumbing tape around the idler wheel arm to damp vibrations.
Is that a brass front plate ? I am looking for a brass or golden colored plate like this ( custom dimensions). Not particular about thickness and even 1-2mm are fine. Any pointers ?
what lovely work, quick query - would the idler constantly engage with the platter rim or have you factored in the on/off lever?
Thanks Sadik!Congrats Bro....![]()
