The only way to arrive at what sound signature one prefers is by hearing lots of setups.
Thanks - I wouldn't like anything better. BUT How do i go about it? This seems to be the common recommendation
I did go around Bangalore hi-fi shops when i was making my initial speaker purchase but i have lots more ground to cover.
However i feel bad about troubling these shops, doing this, since in the end i do not know who or what i will be purchasing . The hifi shops also seems to have acquired a revulsion to "2 channel" guys since they are more demanding in terms of audio quality and want to do more level comparisons switching etc, compared to someone who just want more speakers/more power etc.
Is dealer auditioning the only way to hear to setups?
Can provide some more information to help people pitch in?
1. Budget
2. What speakers will you be using with the new amplifier ?
3. Have you heard any system that enthralled you ? And, what were those qualities that stood out as compared to your current system ?
......Nowadays, most people who have played this game for a while define an end goal w.r.t the “kind of sound “ they want from their “ music system “. This can be different for different people. That, I think should be your first step. The next step - > loudspeaker -> buy an amplifier that works well with that speaker.
The reason I was looking to buy an amp + DAC 1st is that - that's the bit i saved on when i first made my purchase - and the old Yamaha i had bought seems to have given up the ghost. So i need a replacement urgently. The speakers i have currently is a set of KEF R500.
When i was running around trying to buy my 1st set of speakers i was asked to buy an amp 1st and then get speakers that matched to it. So i used to carry this 25 kg Yamaha everywhere to audition and soon i stopped it. The main difference i was seeing was that either slam was lesser in the dealer ones than the old yammie or the newer amps were clipping/distoring at higher levels. So to save effort i stopped carrying it everywhere. At that time i decided that amp difference was not so much that i could differentiate / bother about it. To boot, none of the dealers had a way to even switch between different amps in a level controlled manner.
So based on this experience i just sat down and dug through all the forums and started gathering data on amps based on measurements alone since i couldnt hear them anyway. After all my readings i settled on 2 amps based on
- published measurements
- based on which famous reviewers who themselves have upgraded to one of these.
- Many of the big brands also seems to have moved to hypex modules in their flagship amps (eg Marantz).
Problem though is that i haven't listened to either of these before hand.
- Hypex kit - nc400
- Benchmark abh2
So based on my experience i should go for 1 and save some money. But this chart in particular has been giving me a headache... No other amps seems to produce a square wave this bad. Even regular class A/AB seems to do a better job here. Yet there are so many singing praises of hypex.
Hypex stereophile measurements
But based on THD etc the hypex is still much better than many of the amps out there. But abh2 seems to blow everything out of the water wrt THD distortion etc - 2x better - but at 4 times the cost, considering its 2x as expensive and offers only half the power. It does seem quite an outlay for something i havent heard yet and for removing the distortion i might not have been able to hear anyway in the 1st place.
Since i had not heard either i was really concerned on whether i need to spend so much more for a less distorting product. Admittedly i dont have a choice in that list of mine which represents a type of sound i like.
I was also troubled by the fact that my entire list is based on measurements (& some past experience while auditioning) since i really haven't had an opportunity to hear many setups. I have not had a chance to hear a "warm" / tube sound either. So i was holding out before i swiped the card
Hence the question which i wrung out of my soul and posted here for your kind consideration.
Arun
ps : Type of music i listen to most - Soft rock (Tracy chapman, eagles) reggae and country music and soft hindi/tamil/malayalam compositions. I do enjoy my occasional fast pop and punjabi but never as many times as the slow/softer ones.
ps : The end game reference was coz i fear i might not get another budget allocation to spend any more for this. (Age/retirement etc
