Where to buy a brand new TEAC or TASCAM deck from in Bangalore?
Sandesh
Hi guys,
After shitty luck with two old tape players, I am contemplating buying a brand new set. Any advice where I can get the above players and preferably at a reasonable price (30k). Any suggestions who is a reliable dealer for these tape decks or any other good brand?
Hi guys,
I have a teac CD player with dsd support also..
Do you run a store? Any links?
if i have one does it mean i run a store??
i am an audio enthusiast and i spend a lot on my gear. i sell it after a while.
thats a trait with most of audiophiles.
let me know if you are interested, then i can share the details.
I think you missed two points here "tape players" and "brand new set "
Hi Sandesh,
Do post your findings and what you end up buying. I'm keen on getting a tape deck as well but wary of going down the used gear path.
Tascam and Teac decks do look promising if you get hold of authorized dealers.
Good luck with the hunt!
Hi Sandesh,
Hi Jayanth, they cced it to their team. Awaiting a reply back...
