The Giveaway Thread
Hi, thanks for the generosity. I didn't realise earlier that the 1st two are only plates without amps. If so then please give them to some one else as I have no diy skills for electronic build. Sorry for the confusion. I will be happy with just the plate which has amp built into it. Will pm you the address.
Dr.Lakshay,
As mentioned in PM, i could salvage few Scandyna plate amps. These ones are powering up... (see the indicator)
of these if you can revive at least two, pl let me know... I can send you the enclosures and drivers for them.
Will be sending five amps.
Cabinet and Dual Coil 8" Kevlar Cone Driver:
110 Volts, portable halogen work light: Ningbo Geosun
if no one wants this, can I have it please?
since i don't have a step down transformer, I plan to modify it for my use
so please consider me only if no one else asks for it who can use it as is
regards
Hi Krishna,
If no one has requested the halogen lamp yet can i have it please
Dr.Lakshay,
View attachment 40832View attachment 40834
View attachment 40837View attachment 40839View attachment 40840
Wow. That's way too many. I really appreciate the gesture. I need just two. Will shoot you a pm.
Toshiba CD/DVD player with remote. 2 lens system lugged from Germany many years ago. Drive is working fine but am unable to read discs...
Dr.Lakshay,
Oh wow. Do you have enclosure and driver for all? Can i have 2 of them?
MaSh
Can I have this? If no one else wants it, I would like to gift it to my driver friend after trying to fix it. I personally have an OPPO 103.
I will bear the courier charges.
Hi Doc, though it is powering i don't know the overall condition of the amps...
have them checked with the technician in your area and see how many he can revive.
If you still think it is too much to handle, i request any other member to come forward and take this up.
@ Hydrovac...may I have one please. Thanks
Please check PM
Let us hope we get more than two online...
OK. Will get them checked and repaired. You have my address :)
No hurry, do at your convenience...
Although technically an elective title, theoretically speaking... most Emperors are famous for their tyrannical reigns of terror. so,please...
I am sorry if I hurt you in any way. My sincere apologies. There is the Emperor Ashoka and Akbar with the Emperor status. :)
