Playing flac files in Audiolab 6000A
MOUSUM8
guwahati
So there is no usb-in in Audiolab 6000A. How do I play Gigs of flacs from my laptop ? Another external DAC with USB in, using a DAP like Fiio X7 Mark -II , burning then into Audio CD ( Some are of higher resolution then CD) ? What might be the best way, any suggestion...
Use any PC digital with coaxial out or optical out .
My suggestion is allo digione board
Or
Any of the USB to spidif converters
Example - singxer or gustard
bluetooth is another source, you can connect Laptop to Amp through Bluesource,
In my case, I connected my NAS (that stored all my audio&video stuff) to BDP (sony x700) and BDP to Audiolab amp.
That sounds great.
Or
@rikhav - So, in my case, I can use an optical mini-toslink to toslink cable from my macbook pros' earphone out into my Audiolab 6000A right ?
Have been thinking about this, just need to buy this adapter that goes into the 3.5mm port of my MBP as I already have a regular toslink cable lying idle.
Yes that you can since you have a Mac
Also you can try USB and then decide what works best for you
So, if I look at what I readily have vs what I need to arrange or buy - I have the toslink part. Or I also have the dragonfly Cobalt that I was planning to sell off soon. I would need a 3.5mm TRS to RCA cable to provide input into one of the AUX input of Audiolab.
Or
Found "Signstek HIFI USB to Coaxial S/PDIF Converter" any idea how is it ? Could not find the brands you mentioned.. Thanks
Hello @Haribabu: But then bluetooth medium will compress the FLAC or other HighRes formats while transporting to the amp !! Isn't it ?
Nothing, it won't compress, you can see same quality.
One best quality of Audiolab amp is, it play Bluetooth content without degrade the sound quality.
