The Giveaway Thread
Can I use this as a repeater to my existing Google Home wifi router? Repeater in the sense via WiFi signals only and not using the ethernet port.
You can use a wifi modem as repeater by connecting it with your existing internet router or modem through ethernet and disable the DHCP in new modem. Then the new modem will work as repeater
Long back, planned a DIY system for my weekend villa, not executed... so, cabinets for giveaway.
Loudspeaker enclosures designed for small bookshelves, with 4" to 5 1/4" woofer and 1" tweeter.
These were the drivers intended to be used.
3/4" MDF enclosure, black laminated with extra teak baffle.
1 Dim: 280 height x 155 width x 140 depth (4 Nos.)
2 Dim: 270 height x 155 width x 205 depth (6 Nos.)
3 Dim: 280 height x 145 width x 220 depth (2 Nos.)
Sub woofer enclosure of same finish 425 mm cube
Extra baffle and grill for the sub.
Few desktop computers with monitors:
System 1
There is a thin green vertical line on the left side of the screen.
System 2
System 3
System 4 (Big screen)
DUNE HD MAX (SMPS module OK, but not powering up)
View attachment 43506 View attachment 43509View attachment 43513
System 1
Would love to have a monitor, if possible, preferred system 2/4 for monitor
Thanks in advance.
System 1
System 2
System 3
Would like to have system 4. Hope it can run java
Can't attach more than 20 images, so posting more items here.
Sub woofer amp 60+60 watts, same circuit as what i posted earlier (Pre-Power combo) only this has a filter, don't recollect the roll off (60, 80 or 100 Hz)
Doesn't have phase control... the filter can be disconnected and used as a two channel power amp.
Sherwood remotes:
Cambridge Audio remotes:
Various assorted Tubes: box full... haven't catalogued.
View attachment 43551View attachment 43554View attachment 43555
Sherwood remotes:
Great stuff sir.
Absolutely astonished.
Kudos.
System 1
System 2
System 3
What's the driver size you have planned for the subwoofer?
I would be interested in the subwoofer cabinet. I think my thread on subs must have been seen by you. Also got the usb cable. Thanks. What do I owe you?
Thanks in advance.
Can't ship heavy and delicate items... pl pick them up locally.
If any 6922 tube pair I would love to have it
Will sort them out and update.
Can I take the dune HD. Hope it comes with a remote. Will try repairing it.
Not sure about remote... can ship the player.
Actually i had this driver... so planned exactly same enclosure.
Can't ship it... pl refer to courier dockets for shipping charges.
Can i have a Cambridge audio remote which is in good condition if possible.
OK... will have to check.
Hello,
I'd like to pick up a pair of the speaker cabinets sized 270 height x 155 width x 205 depth. Please provide details for local pick-up.
@hydrovac I suggest that the PCs be donated to a school for underprivileged children. I know of one organisation which collects clothes of children which it passes on to such kids.
Edit:
And, kindly reserve 4 Nos. 6SN7 or 12SN7 tubes for me. I'd like to use it for tube rolling on the Aikido Octal preamp that I'm going to make.
