Budget 55 inch TV - Suggestions
gopscreative
Bnagalore
Hello Guys,
I am looking for a budget 55 inch option around 35k. This TV will be mainly used by my parents who mostly watch DTH content(Local cable provider with most SD and some HD) with some occasional OTT platforms like Netflix, Hotstar and YouTube . Viewing angles are straight for main seating and 35- 50 degrees for side seating.
No preference on OS , but should be easy to use(Mom is little techy, will pick up android quickly and uses a android phone)
I am looking in to below options . Please provide your inputs and it will be gladly appreciated!!
1.Mi Tv 4x 55 inch(good customer support)
2.TCL Iffalcon K31 55 inch
3.Kodak 55UHDX7 on Amazon
4.Sanyo Kaizen series
Can stretch budget to 50k if viewing angles are extremely bad on these. LG 55UM7290PTD is at 53k on Amazon/Flipkart with IPS panel.
Hello Guys,
Why don't you look at Panasonic HX450/700 series, Panasonic budget TVs are very promising. Very recently launched.
Hello Guys,
all those tvs you mentioned are quite terrible
check this tv out its a new launch from toshiba owned by hisense
theres a discussion on this perticular tv here please take a look
Hello Guys,
Better consider Mi or TCL, TCL is OEM manufacturer...... using Mi, TCL both I find TCL better over any other budget TV. Choice vary from person to person.....
Hello Guys,
Among these you may consider Sanyo. Panasonic is parent company of Sanyo and they use same panels.
Thanks Guys for the replies.
Well I know mentioned TVs are not FALD. But this is for my parents who usually don't look for WCG, deep black levels etc. The main requirement here is TV with less issues , good after market support and easier interface with price around 35K
