Budget Media player with Truehd & HDMA
Bhushandn
Pune
I am looking for a media player with mainly usb/HDD support and can play all types of audio, video format (HDR10 and in audio true HD or HDMA) my preference is for audio quality. I am going to use it with yamaha AVR. Also your suggestion is useful for any alternative to the media player like laptop/bdp.
Does it available in india? I am looking for the box which is available in india or can be brought easily.
H96 Pro plus will fulfill your needs, please try it
Since you are interested in nvidia shield, check out the following which I found only on Flipkart. I personally have not used or tried this but seems the cost is reasonable for a certified Android TV 9.0 device using native Android TV interface similar to shield.
Cheers!
Actually mi box 3 with android 8 was last compatible with streaming Dolby HD / MA.
Mi Box 3 (MDZ-16-AB) which can pass through DTS-HD-MA and Dolby True-HD audio
There was one member selling the same last month. Try looking for sale by members section.
Edit : found the thread.
Thread 'Mi Box 3 (MDZ-16-AB) capable of DTS-HD-MA and Dolby True-HD' https://www.hifivision.com/threads/mi-box-3-mdz-16-ab-capable-of-dts-hd-ma-and-dolby-true-hd.84442/
Disclaimer: I'm no way linked with seller. Just try to help OP.
the zidoo z9x is available in india through melody media, i have bought one and should say its a great product to play 4K content it supports various inputs like external hard disk, Pen-drive, NFS, SMB, the output audio if you have a AV receiver will blow your mind.
you can buy them here
Zidoo Z9X
you can contact Melody media Amit on 6363772699
