Dear All,
I am looking for Suggestions for Smartphones, which can be used as USB - C Audio transport ?
I recently used my Samsung Galaxy Note 10 as Roon Audio Transport / Endpoint as shown in the picture ( Samsung DOT is Default output) and surprisingly it sounded better than Allo USB Bridge Signature in Overall SQ wise. Since Roon gives an Option to control any endpoint from any other Roon Remote including the Volume control, it becomes quite easy to control for streaming purposes.
As Headphone audiophiles tend to use Smartphones as Audio transports to connect to their DAC/Amps; i am looking for suggestions for Smartphones preferred to be used as USB Audio Transport, I will be planning to buy a Smartphone to be used as dedicated Streamer/Transport. I am Looking For USB C Smartphones, or iPhones work better overall? I will be Planning to connect to My DAC with USB B input. So will be looking for USB B to USB-C Cables or Lightening to USB B cable as applicable. i am NOT looking for Smartphones with better in built DACs.
