Hello!
I am planning to build a new desktop tower (with the new Nvidia 3070 GPU). Also planning to buy a good speaker too.
Usage: Gaming and movies mainly. Occasional music. Will also android connect phone/echo dot
Budget: upto ₹25K
Room size: 15 feet x 10 feet
Desk Placement: Middle of the 15 feet wall against it. The speakers and subwoofer will all be placed on the wooden table
I have been researching a lot (kinda overwhelming) - broadly there see,s to be two types: Active and Passive.
Q1 - Is it worth to invest on passive speakers for 25K budget or simply go with active once. I have no clue on the passive setup.
Q2 - If going the active way:
Please let me know if Passive or S350DB or R1850DB + 100W NS SW or there is any other alternative?
Thanks!
Budget: upto ₹25K
- I had first shortlisted for Logitech Z263/Z65 speakers and soon learnt to stay away from it as per various forums.
- Next choice was the Edifier speakers - they have lot of bookshelf speakers which I read they are suitable for desktop setup too for gaming/movies. Looks like 2.1 setup will give rich audio experience and I saw the S350DB model which is indeed expensive than Z263. However, it they are really worth the price and will have a long life, I am willing to spend.
- I also looked at Edifier R1850DB model. This seems promising as I can invest only around ₹14K and then gauge if the bass is good enough. If required, then I can add in a active subwoofer later. The only good subwoofer I can see if Yamaha 100W NS SW (has range of 25–180 Hz and is sufficient?) which I will invest after couple of months. I think this will give a better audio experience compared to buying S350DB?
Thanks!
