+1 on the respirator, are you using ply backed veneer, paper veneer or fleece backed? I prefer paper veneer, trouble is finding good glue for that unless you have a vacuum press, even though it's available no one will sell to small businesses or DIY guys.
This is a different kind of Polish with my own personalized process.I don't understand. You stained the veneer, applied Clear Coat and now are going to apply polish over Clear Coat? What was the point of applying Clear Coat?
Thank You @tuffLooks beautiful.
Very interesting , would love to see the final outcome!Its been a quite long time since I last shared my Projects on our Forum. So now i am up with something Big. I can say it will be a monster.
I am up with a new project a 3 way tower with Three Individual enclosures stacked one above another. Interlocking is provided so the enclosures wont slip off & Isolation is provided for interlock joint to absorb the vibrations and prevent any kind of rattling noise, Image of same will be shared later once i have them in my hand.
So moving ahead, The Bottom Enclosure will be Bass, Middle will be for Mids & Highs & again top will be for Bass. Like the below image for better understanding. Total Height will be more than 7ft.
I don't wanna disclose much about the drivers so i will not mention any details about it except for their sizes. The Bass driver will be 15 Inch, Mids will be 10 Inch & Highs will be Ribbon Horn
I have chosed HDF as the construction material having thickness 25mm, The Finish enclosure will be veneered. I have chosen a off white shade veneer and decided later to stain it with our choice of shade. The Veneer is glued to HDF before cutting. It was glued & then pressed on a 100 TON hydraulic press and left overnight for the glue to dry. Its like 10 trucks stacked one above the other on the glued sheet.
Below are photos of Cutting on CNC router
The 45 Deg cut on the edges to match the flow of veins of veneer on all sides will be done with circular saw. This job will require a great precision and will need jig to achieve the accuracy it need. And yes Challenge accepted Because I know i can do it.
I will share the image of Jig soon.
Sadik
Thank You Bro,
The Crossover is designed, but yet to be made.
Below is the Photo of the cutting blade i am using. This Blase is used to cut aluminum sections.
The marking Jig which i mentioned in my first post.
Below is the video how i am using it. it will save huge amount if my time.
The Demo Wooden panel in Short the Final results. This chamfer will be done to all the six panels of the enclosure. In total there are 6 Enclosures ... so lot of work to do. I will start the actual work from tomorrow.
Sadik
Dear Sadik do you have in-house facility of 100 ton press facility or outsourcedThis is 4mm veneer sheet glued with 24mm Action TESA HDHMR sheet. It is glued with Fevicol SH & Press fitted on a 100 Ton Press machine & left overnight for drying under pressed condition.
W
great work. I am both into woodworking and audio. So i have a few query.
1. From where do you sourced your audio components.
2. And from where do you get your veneer. Is it available online.
as i am from the remotest of region in India, online sourcing is usually my only option
Thanks for the information sirAudio Components mostly from online sites which i have mentioned below.
1. THE AUDIO CRAFTS
2. AUDIOFY
3. ELECTROCARTS
4. DIY AUDIO CART
& for Veneer i purchase it locally.
