babbudi85
great Build looking forward to it.
Hi all DIYers,
Building a 300 watt Hi-fi power amp, which we designed and prototyped few years ago.
Please follow the links for details.
310W Power Amplifier - diyAudio
310W Power Amplifier - Page 4 - diyAudio
PCBs have been fabricated and gathering all components on hand.
Few pictures of the same.
Hi HydroRock
I'm in Complete Awe of your Genius Work:clapping:
After this I'll be sending a PM to you Pls check it.
Aaron
Hi Sir,Just to update that I got the PCB made in double layered, with provision to mount the power transistors on board.
This will eliminate the hassle of hard wiring the trannies and make it less prone to joint failures which i was experiencing in earlier builds.
Top side:
Bottom side:
These are the earlier version PCBs:
There is also a label included in the hardware...Nice and sturdy looking cabinet @hydrovac
I see a rectangular recess on front panel. What is that for?
Suman, first i neeed to build the dual layer PCBs for evaluation and then order for more boards... BTW i have couple of earlier version PCBs if you are interested.Hi Sir,
Any extra PCB's available ?
Thank you, I will wait for the dual layer PCB's as it saves lot of efforts.There is also a label included in the hardware...
Top side:
Bottom side:
Nice to see after all these years ...Nice to see a high power amp project on the forum.
Wow, i love those metal can trannies..........![]()
Back in the 90's I used the SANWA transistor tester meter ST80 to measure hfe and test bjt's and power mosfets.Searching for few more components i came across and ordered this hFE tester...
