4K Led TV 50-55 inches
raghav080
Amritsar
Whats the best option?
50 inch Sony X74
55 inch Hisense QLED
50 inch Samsung Frame 2020 -
Budget option 50 inch VU cinema action.
I need two TV's 50 inches for bedroom VA
55 inches for Lobby IPS panel. Pls suggest I'm gonna buy one immediately. And one after 2-3 months so can buy any one right now.
50 inch Sony X74
Hisense u6g qled 55" is first choice, Samsung frame 55" is second and Sony X74 is the last. Sony 8000 series itself is not good leave 7000 series aside. Vu 50 is ok if you don't bother about brand and just use it as long as it gets repaired and then dump it. Sometimes you could even get a 48" A1 OLED for a smart price just a little more than those you mentioned.
Thanks a lot for your inputs. Much appreciated. I have closed down to
VU LX55 - 39.5 k 3 year warranty
Hisense QLED 50 K 1 year warrantyis it worth spending 10.5 k extra for u6g.
Gonna order tonight.
Thank You!
Thank You!
U6g is FALD. So yes.
I want to purchase a soundbar budget 10-15 k.
2.1 or 5.1. pls suggest best buy
If it's dolby , does this FALD support it?
