Ravikiran 33
Samsung frame does not have dolby vision certificate thats it .. as far as i know i can easily play dolby vision content . Televisions with less than 400nits brightness also have dolby vision support but the pq is sub par in them while playing dolby.
Coming to hisense yeah its h8g as far I remember. Subject to correct though.
3 years warranty is good and u can also get additional 2 years extended warranty separately.
It is deification vfm product but it depends upon our luck when coming to electronic items durability. If you are in a tight budget then only go for Toshiba otherwise go for top 3 brands which is always advisable
