6x9 speaker recommendation
aeroash
Mangalore
Hello Folks!
I'm looking to replace my Polk Audio DB691, they are too harsh for my ears. I got rid of the DB651 in the front, the harshness was getting to me!
I'm looking to just switch the rear 6x9s for now, any recommendations for warm sounding speakers will be really helpful.
10k budget.
Look at Hertz components and coaxials, They are very good value for money and sound balanced as well.
I would recommend you start from their Cento series.
They only do through dealer networks. You can check in local car audio stores.
Or check with the following company who are the authorised importers.
Orix Hi Fidelity PVT. LTD.
556, Udyog Vihar, Phase-V, Gurgaon-122016 (Haryana)
Gurgaon, 122016
+91 124 4552659
