72 Hours with Samsung KS7000
I bought the 55" KS7000 in Delhi in July....comes packed with a marketing sticker on the top left of the TV - about 6" wide and half the screen height - I noted permanent blots left on the screen under this sticker. Samsung replaced it with a new one in Sep, but same issue. Again Samsung provided me with a third piece and viola.... same issue! Do check your TV as well - examine the screen surface closely with the TV switched off and let me know if you also have the same issue.... I had a separate post running on this issue which you may refer to for pics.
@sidlal: I had read your post before I bought the TV and the first thing after installation I did was to check the sticker. Samsung person left it untouched. Unlike I thought, the sticker did not have any glue on the panel side but it is on the flaps which fold around and sticks on the backside of the panel. In fact the sticker kind of floats on the panel surface.
I removed it carefully and found no scratches. It is really surprising for your case and hats off to you for getting the 3rd unit... I also noticed that panel surface is not easy to clean and small spots, finger prints etc do not go easily. I use the soft cloth that came in the box to gently clean the surface.
In-depth review of the Samsung KS 8000 - NeoGAF
KS7000=KS8000
KS8000=KS9000
KS9000=KS9500
KS9500=KS9800
@dinjo: KS7000 != KS8000.
KS8000 is available in both US (UNXXKS8000) and EU/UK (UEXXKS8000) whereas KS7000 (UEXXKS7000) is non-US model.
Differences as taken from Samsung UK website are as follows:
Motion Rate: "Supreme Motion" vs "200"
PQI: 2300 vs 2100
Micro Dimming: "Supreme UHD" vs "UHD"
Sound Output: 60W vs 40W
Speaker Type: 4.1CH vs 2.1CH
loT Client Application: Yes vs NA
Tuner: 2 vs 1
Digital Broadcasting: DVB-T2CS2X2 vs DVB-T2CS2
Data Broadcasting: MHEG 5 vs HbbTV 1.5 and HbbTV 1.0
Besides there is design difference as well.
Check full details here:
Samsung's 2016 TV line-up - full overview - FlatpanelsHD
UK Site: Samsung Tv 4K, SUHD, LED, Quantum Dot & Curved Smart TVs
US Site: 4K SUHD TVs - TVs | Samsung US
went ahead with Purchase of KS7000. Its magifique...Loving t.
Dolfin.. Let me know how uou check panel hours.
Info Menu Mute Power combination for service menu aint working.
I had to change my TV this year. I had been scanning the internet ever since 2016 lineups were announced in CES. I was particularly interested in LG UH850T and Samsung KS7000. The former for Dolby Vision & 3D and the later for UHD Premium Certification (associated hardware features). Around July I saw the LG model in showroom and I was totally disappointed with the PQ. The panel lacked contrast and blacks were not so deep. Colours were also looking dull for my choice. So I decided to wait for Samsung. Later came KS9000 and I was quite amazed to see the PQ. Subsequently KS7000 also hit the shelves.
Now it was choice between 3D and PQ. I finally decided to sacrifice 3D for PQ and got my Samsung KS7000 installed two days back. Here is my review of the model:
Build Quality (8/10):
Build quality is quite good to justify SUHD range. This TV is almost bezel-less and can be fitted perfectly in tight space. Mine is installed in corner and I could not find better fitting for its size. Though I am not using the stands, I felt its design is not good. They take lot of table space and rotation is not possible. I also heard that being screw-less they are prone to fall down.
Bundled remote feels solid in hand. It is a Universal Remote and does not require line of sight. Smart Hub Interface scans the device through HDMI and sets up necessary codes. The process is not smooth like Logitech Harmony but descent for a TV. Some buttons like power, back etc. are flush and sometimes do not click.
One Connect Box is really a smart idea and makes the ports easily accessible. Had it been on the back side, it really would have been a great pain since my TV is in corner. Of course it is upgradable though I am not sure if Samsung will keep its promise in releasing upgrades 2-3 years down the line.
Interface (7/10):
Unlike LG's WebOS interface which looks kiddish, Samsung's new Smart Hub looks more subtle & premium. Interface adds a translucent white background and nice animations that are not overly done. UI is responsive and intuitive. Menu options offer both quick and expert modes. I found that quick modes for picture and sound settings are quite enough for a normal user. I did explore the expert settings but did not find much improvement in PQ. I personally like "Natural" mode. (Other modes are Dynamic, Standard and Movie).
Features & Picture Quality (9/10):
KS7000 is SUHD Model that uses Quantum Dot substrate from Nanosys. It is also a UHD Premium Certified TV meaning it has 4K resolution, 10bit color depth, more than 90% of DCI-P3 colour gamut, HDR, minimum brightness and 1000 nits and black level of 0.05 nits. Being a VA panel, it does have deep blacks (its no match for OLED but still very good in LED-LCD category). The brightness, I must say is really exceptional. Streaks of Sunlight truly looks like sunlight! Colours in Dynamic mode are oversaturated but descent in Natural mode. Of course one can set the colour according to personal taste and every possible aspect can be adjusted in expert mode. Like typical VA panel picture becomes dull at extreme angles but since my TV is in corner, I do not need to see it from extreme angles.
Unlike LG offering it does not have 3D and Dolby Vision. I felt little bad about 3D. Its loosing luster. Blu-ray Disk Association has kept it out from UltraHD Blu-ray specification. It means 3D will be limited to current Blu-rays only. Dolby Vision is a competing HDR standard (remember Blu-ray vs HD-DVD battle?) that holds water but its optional & proprietary standard and may take some time for getting adopted.
Motion handling is good but not the best for its class. Built-in speakers are good but a separate speaker system is highly recommended.
My Overall Score (8/10): :thumbsup:
Is the price mentioned for 55 inch? I was looking for a tv to watch olympics and ended up buying lg uh850t ...i wanted 3d ..but boy had a night mare fir 6 months niw and currentlyvon 3rd screen other 2 being replaced ..have been a lg fan boy but last purchase of LG their service is pathetic ..quality control is no less than a road ride vendor ..but YEAH u get all the features on planet earth ...but it comes at a cost ...few videos excels few disaapoints..i got mine for 1.66 lakhs in june without freebies +12k insurance ...which is now available for 1.4 with lot of freebies. Lesson learnt not to purchase anything which absolutely new..wait for 3months atlast
@saisagar: The price is for 49" model. Samsung is more expensive than LG UH850. I did inquired about LG and got the lowest quote of 1 Lac (49") vis-a-vis 1.4 of Samsung.
Got a real sweet deal for the 55" model here in Delhi at Sargam Electronics. Croma also has a fabulous offer going with unlimited 5% Cashback and was close to Sargam's price at 1.75 after Cashback plus the Samsung soundbar offer for which the dealer offered to give me 10k. I decided to keep the soundbar and gave it to my cousin for 10k so all in all ended up paying 1.65 in total from my pocket. Didn't need the soundbar as I'm investing in a 5.1 setup (it's a decent one otherwise).
Sent from my Nexus 6P using Tapatalk
I think you have not heard of horror stories of Samsung panels they had lottery panel for years I would avoid Samsung in India if you are in US and UK then yes go for it
