Acer H5370BD - Impressions
My friend too ordered it yday (the last day) and the projector should reach him by end of this week. :clapping::yahoo:
Thats where the good part ends. :indifferent14:
He is not sure when he will be traveling to India and right now I am not aware of anyone who are. So its going to lie down there until some good Samaritan can get it for me. :sad:
We are in the same boat brother !!! Waiting for some good samaritan from Atlanta to get it home for me... and welcome everyone to Acer family. :yahoo:
Congrats max123_ind on your purchase...
please do not order anything from ishop these people are crap no status of my PJ which was booked on 20nov...today i called and they are saying they may refund if no status is updated by today
I was suspicious of them from the beginning. I did read lot of comments on the web about people not receiving items , delays, poor CRM etc.
Yes from newegg only..recieved the call from them late in the evening saying the product is with their newyork warehouse(i think they are lying )as they said that they will confirm this tomarrow.i was eagerly waiting for the product... they have ruined the entire mood...
i am getting this one .. wires bought for surrounds for new room setup.
good reviews on amazon.com 100's of them
same stuff from amazon.in
Aurum Flat Series - Flat HDMI Cable with Ethernet: Amazon.in: Electronics
I have similar but with different brand name.Looking this one I can say the cable has hard cover and if you need flexible,this is not the choice.My cable started giving trouble with video signals.Get MX.Older one is still running fine.Its 1.3 but carries 3D signal too.
i wudnt need much flexibility but i have done wire concealing and this has to run inside it. across the wall .
28ft-35ft is what i need without stretching/slagging too much. i will recheck the shortest possible length again today.
as in the picture this looks i can give it turns at 70 degree. needed at 2 places.
still in doubt. prices seem to be attractive and aurum has good reviews. need for 3d for the same projector via htpc/xtreamer/bdp.
Aurum Cables Version 1.4 24K Gold-Plated High Speed: Amazon.in: Electronics
Aurum Ultra Series - High Speed HDMI Cable With: Amazon.in: Electronics
all these are 30-35 ft ones.
which one of these suggested ?
i am going crazy as getting PJ next week so trying to setup before it arrives to keep things ready
Projector Ceiling Mount Brackets,Projector Ceiling Mounting Brackets Suppliers From India
Projector Ceiling Mount Kit 1.5 feet*1.5 feet( 63 to100 centimeter) Power Seller | eBay
Ceiling Mount Kit 63 cms to 100 cms
celing i guess is 10 F and i want the projector around say 7.5 or so as seating is 6 inches above ground level. so dont want it too high like 1st row in threates :)
as of now no screen . i plan to use wall as screen for a month or so and if it becomes an absolute necessity only then i will go for a DIY screen else anything under 10k.
my throw distance is only 9 feet with a dark room so i am guessing even in eco mode it will be super bright.
But i think with that throw ratio you can achieve a maximum screen size of 80-84 "(Correct me if I am wrong).Isnt that a little less.
that is true. i will get screen of 79 and with max zoom it will come down to 85 i guess. the room that i have converted to small HT room is 10-12 in which 12 side has door on both sides.
entry and balcony door. hence have to fix projector on other side . above window with empty wall in front.
:( wish i had a bigger place. but as for now from 42inch LCD 84 will be a huge upgarde
