Acer H5370BD - Impressions
Pics of My Proj
Cost - 37.5 K fro ishop
Space limitations so throw is at 9 Ft
I hope that is a DVD/DVD Screeener RIP and not a Blu Ray Rip.. Else I would be really concerned.. the image seems quite washed out !!! pls confirm Jatin..
Pls also let us know where you got that wall mount from ? It looks great :)
Congratulations again to all the new owners, enjoy your big screen...
Even I have the same 3D Corp glasses, they are functioning well...
If you are wearing prescription lens, then you need something bigger than Saisonic I believe. This is what I bought and I suppose theironhorse also purchased the same. They serve well without any troubles.
Amazon.com : 3DTV Corp DLP-LINK 3D Glasses 2 Pairs for ALL 3D Ready DLP Projectors and ALL Samsung and Mitsubishi DLP TV's : Electronics
i did not get the 3D corp ones but went for the sainsonic ssz 2000 dlb. rechargable ones. got 2 of them and they are pretty decent. syncs well in a fraction of time.
@ theironhorse -Many thanks for valuable inputs...
Planning to use the package forwarding services and order from Amazon when the prices are dropped ... also would like to know from you / forum members if it would be good idea to order 3d glasses and HDMI cable (35feet) in one go while ordering projector? i.e. to save on cost by asking package forwarding company to consolidate all the items in one package?
If someone can provide me web link for the best HDMI cable, ceiling mount and best 3D glasses compatible for this projector .. it would be great help...
For now I am planning to project on my off-white wall so will be considering for screen 16:9 format after a while ...
Shrinivas D
get 3d glasses and projector from US rest mount and cable available here for pretty cheap prices.
The Rip is full Blu Ray Some 30 GB Rip( Legal one )
Its the damm flash from my SG3 that ruined the pic.
The screen and Mount i got from seller , Mount 1 K , Screen 6K.
How much is landing cost for this projector if ordered from amazon .and do they accepts debits card ??
i thinks its something around 42000, when i checked 2 weeks back. This includes all the charges..
I think they will accept debit cards..but haven't checked.. may be someone else who have used can comment. ;)
More teasers.....
Blacks are good.. havent wall mount it yet so working on make shift adjust ments..
More teasers for you
@theironhorse - Which movie is this from ?
Amazon does NOT accept debit cards.. they only accept credit cards.
"sorry for the off topic"
friends this issue was frequently discussed on this forum.
there is dedicated thread for this in the forum. I myself was also very much curios for using debit card on amazon.com. some fms say only cc work with amazon.com, some say vc works even some say debit card also work.
i myself tried with axis bank debit card but it didnt work. I als tried vc too but :sad: later as suggested by one of fm samyukta obtained the chip based titanium reward debit card from axis bank. but it also didnt work so i was thinking of getting cc from axis bank.
however suddenly i received smms from icici bank for allowing facility of international purchase on my 8 years old debit card for rs ****. (this card is very rarely used) . and to my surprize i tried same for a 2 dollar e kindle book on amazon.com.and the transaction was completed within a minute without any hassle.
now my question is
that amazon.com is delivering benq w1070 at Rs 77500/ to India (all inclusive). will be the good decision to buy directly the projector from amazon .com in view of product safety( i am aware that there wont be warrenty)
please advise
uttam
now my question is
please advise
uttam
Without bill you can buy it for 85 k in india itself I guess. Ask someone to carry else no point spending 20k for shipping it sells for 890 $ or less
friends,
benq w1070 available at $799 today. The landing cost to india is 70k.
please advice is it safe to buy directly from amazon.com
please guide
uttam
I bought my Optoma HD66 from Amazon.com
No hassles I faced. Landed in about 12 days.
If you are ok without warranty, you could go ahead.
Folks am a little stuck here. People who have wall mounted it. Can ya guys help me. Basically its a universal mount that I bought. .
Now the pj does not have 4 holes in a square instead has 3 of them in a triangle.. pleasr suggest what n how can it be done..
Do I buy a square steel plate and drill holes and then use it between the mount and the pj. Also what kind of screws are needed..
No, not needed. 3 arms will hold the projector fine. Just use the mount in the same config that you have pictured.
Screw size, refer to the projector manual. They would have it in there.
Ironhorse, I am alos using the same kind of the mount. I got the help of a technician to do the installation. Actually we had faced some problem in setting up the correct throw and position. But atlast it was done after lot of hours.
Anyways enjoyment matters at the end of the day with the big picture:ohyeah:
