Hey...a nice room u hv there..
I've recently ventured into some acoustic treatment for my drawing room as well which i set up as a listening room.
In short, to go the treatment route there are many ways to do it from DIY to ready made beautiful panels. But that will be a bit costly and require a lot of panels given the space. But they do have colour options from wooden to white and grey etc.
The best way is to get a big carpet first and throw it right in front of ur speakers to absorb immediate dispersion. As a carpet would cover more area compared to panels etc.
For the big windows u can install rollable ultrathin wooden/bamboo blinds u can pull done while listening while maintaining transparency for decor and light when suitable weather.
Last would be to add few acoustic panels in one by one like a pair of two on one wall, then two on another so on until u feel it's enough.
I got some wooden panels for myself from a Mumbai based co.called aural exchange. Mr. Ashutosh is the owner. He will also suggest you somethings if you ask n prolly ask u to share ur room pics for analysis. If u don't like wooden n think might spoil the looks u can also consider white panels.
In my case i asked him to customize the John Darko design as it was not available and GIK acoustic is expensive. To my surprise he was able to do so at default price as his existing panels. So basically i gave him an idea about the design how it can be in demand as many beginner audiophiles follow him. So he has the same design added to his collection now at the fraction of cost to the GIK ones. Super expensive. These are much much cheaper.
Pic below is a sample of my panels. 2 each on a single wall and rest a medium sized carpet in middle. As not a very large room. Later i put two small carpets in front of speakers too.
Check out the website
Buy Wooden Acoustic Panels in India DIY at the lowest and cheapest prices. We offer same day shipping with 24 hour delivery. Buy brands like Auralex, Nankarrow, Aurica, Primacoustic, Ultracoustic, Anutone, Armstrong. Vicoustic | Aural Exchange - Acoustic Panels & Sound Proofing | Noise &...
www.auralexchange.com
Explained Perfectly:
I do believe if u put ur set up on the opposite wall where the sofa currently is and sofa where u hv set up currently. It will be very good for the set up as ur speakers will get equal/more space on either sides from the wall and keep them further apart from the cabinet to make space and then toe-in 10-30° firing at ur listening position. U can stand behind the speakers while u do that. Keep the speakers minimum 30cm away from wall or 1.5 - 2 feet. It will create a beautiful imaging effect.
Cabinet might be cancelling the inbetween field also. Mine is rounded on the edges. Hope it helps Try out
all the best.
