Record Player
I had acquired a Garrard AT6 Changer Idler Drive Turntable about a few months ago. From then I was eagerly waiting to get it setup and write a review.
This is a model from the year 1962-1966 made in England. This is a new/old boxed piece and thats how I received it. Courtesy FM Shafic who extended his support in me acquiring this. This materialized a couple of weeks before I acquired the Technics SL-1200mk2. My intensions for this Garrard were primarily to play me collection of 78s.
These Garrards come without plinths; hence this was my first DIY project for a plinth. This came with a headshell and a Sonotone 8T Cartridge specifically for 78s. Needed a set on RCA interconnects and a ground wire.
I started with the planning for a plinth and decided to make a basic box type plinth with marine plywood. Spoke with Setvieboy on multiple occasions and a lot valuable inputs provided. Thanks Stevie. It took me about a month to get the Plinth completed as my carpenter delayed the project by a couple of weeks. The Plinth: Plywood, Veneered and then Polished. I was confused with the soldering bit and Reubens reference chart he shared was of great help. Once, soldered worked perfectly. Mounted the turntable on the plinth and I am due to add squash balls to the plinth base for isolation. BTW, I got the plinth dimensions a bit wrong and if you notice, the height is beyond maybe an inch or so but then again, gives more breathing space to the motor
Gave it a first attempt to play this Garrard last night. When I powered it up, I noticed that this idler hardly makes any motor noise. Tried balancing the tonerarm but I am not sure if I achieved the right results. I need some advice on rightly setting up the tonearm and balance on this Garrard as its not as simple as the Technics TTs.
I will get to the listening impressions right after all the settings are rightly in place.
Looking forward to your advice and suggestions. Please also suggest a decent Cartride upgrade and headshell.
Photos below:
Photos below:
