Advice on Phono Stage (preamp)
AP@1992
Need advice on buying a phono stage (preamp)
Budget - Under 20k
New and used both works.
Location - Mumbai
Chain - Rega Planar 2 ------Cayin A-88T MK2
(KT88/EL34)/Boyyurange MT EL 34 ------Dali Oberon 5.
Budget - Under 20k
Location - Mumbai
Check this :
Alternatively, if you up your budget - the ifi iPhono (first or second gen) should go excellently with your Cayin.
After cartridge , phonos make the most significant difference to sound.
Budget - Under 20k
Location - Mumbai
If you stretch your budget then the Darlington Labs MP7 is hard to beat for any price. Read the reviews.
Re
Check this :
Yes saw this. There is one in the classified section as well.
Contact Sachin. @sachu888
Have reached out to him. Let's see
Read the reviews. Is any Indian dealer stocking them? Can't find ?
Here is another one - Vincent PHO-200
Will check it out.
Will check this out. Looks good. Coming from Vincent Audio, looks like an interesting prospect.
In the same boat, looking for a phono preamp at a similar budget. Checking out the suggestions here with interest, thanks to everyone.
Also, is there a minimum number of posts that I need to get to before I can message another forum member? Just tried to message Sachu888 as was recommended but couldn't. Please let me know, thanks.
I have used a few phono preamps in past,
- CNC Phono (still present as a backup) - 5-6k
- Zen Phono - 16k
- Pro-ject MM/MC Phono Classic - 18-20k
- EAR Phono Clone - 35k
- Pro-ject Tube Box DS2 Discrete MM/MC Pure-Tube - 90-95k
- EAR Phono - 1.25
Under 20k I would suggest Ifi Zen Phono then the CNC Phono, Zen adds a bit of depth and better control on bass
Around a lakh would pick EAR Phono then Project Tube Box DS2 (only with a SS Amp)
I don't think any such restrictions exists for messaging a FM.
- Zen Phono - 16k
- EAR Phono - 1.25
Noted. Will check ifi out
Budget - Under 20k
Location - Mumbai
This will fit your budget (just about) and pair well with the Planar 2
+ 1. Had used it for a few years. A remarkable phono for its price.
Will check it out.
