Advice required on turntable
I wish to purchase a new turntable. budget is 80k to 100k. please suggest about technics sl1200 mk7 also. thanks in advance.
Thank you all for your valued inputs and guidance.I have booked Technics SL1200MK7 from The RevolverClub.From my side , this thread may be considered as close. I will post pictures and feedback once I receive the article and install and use comprehensively.
TT starts 1.5L onwards.
Specifications of 65mm thick acrylic platter turntable
Speed 33.33, 45, 78
Platter material: 65mm thick acrylic (around 7kg)
Platter bearing: ceramic shaft bearing
Plinth: 60mm thick sheesham base (around 15kg)
Motor: Maxon motor from Switzerland
Speed control: electronic switch
Spring suspension feet
Separate motor box for zero vibration transfer
12 inch tonearm with ceramic bearing
No cartridge included
MC cartridges starts 48K
any idea about the ball-park figure for their 12 inch tonearms? (if purchased without the TT)
I am pasting the mail I received from them—
Hello
My tonearm cost Rs. 45,000/-
You can watch tonearm model on my website in different pictures.
thanks & regards,
Tariq Shafeeque
(Design Manager)
