Air tel transmission as far as I have been using is not of such high quality.
So, I got Bandridge rca splitters and connected the composite separately to tv and my denon 2309 AVR.
So I can watch only TV or I can use TV with AVR without having to disconnect and connect again.
I found after up scaling through my AVR and HDMI, there was a perceptible difference in image quality. (My colour was really upscaled little extra also)
I thought many of you can try using this way.
Thought It may help some
The BIG TV box seems to have component out. At least as per the image in their site.
Sundirect has Component output, definitely there is a difference when i hook onto my 37 inch 5 Series SAMSUNG LCD TV.
Only problem i face with Sundirect is, when you change from one channel to another goes into wait mode for couple of seconds.
Ramesh S
sun direct does NOT have component Out.
Also refer to the below link last paragraph says Sundirect set top box has component.
.Sun Direct TV subscription crosses 1 million mark | Televisionpoint.com News
Humble request, do not deny upfront if some one says that he is using something , i think you are not sure what a component out is.
Ramesh S
dude that is a press release for the possible future STB ,the current STB do not have component out u can see it in their manual SUN DTH
sun direct does not have component out.
Boss i swear i am using the component out of sundirect dth, doesn't makes sense to discuss further on this.
Ramesh S
well in that case it would be helpful if u could show some pictures or alteast say the model no/company not that i dont trust u but since i wasnt aware of this also since the sun dth manual doesnt show the presence of component out.did u get some new model?.
We proud Indians never trust each other, enclosing my STB (sundirect) back & front view.
