Sir i have already moved out the speakers to the maximum i can.. will get two separate rugs for both the tower speakers.
One thing i wud want to ask u ia i always feel in movies that the dialogue lack the loudness.. i have cranked the centre channel level all the way upto +11db with fronts being both at +9db.
Also my another doubt was that is it possible that i am getting much better sound in bluetooth( like quite loud) as compared to when connected through amazon prime, netflix or youtube.. like the moment i play through bluetooth i reduce the channel level to +6db. I find it bizarre ti be getting good output through bluetooth. I wirelessly connect my wynk to avr also since my avr has chromecast built in.
Do give you valuable suggestion sir.
Hi. Pls do check whether the Dynamic range control (DRC) or Night Model is ON by mistake, cause I think 11db & 9db+ is pretty hot levels for your room. Also re-check all speaker wirings and input levels for bluray or media player that you have connected to the receiver.
Cheers.
