rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,665
- Points
- 113
The amps are 400w/ch built by Aniket Das @adas in the forum. I believe @sidvee uses smaller versions of his amps.
Monoblock Amplifier - O&B
SSMB1400 Set of Mono channel 400W power amplifier SSMB1400 is a set of Monoblock amplifiers which are designed with extensively overrated dual shielded Toroidal transformers and bulk capacitance to outperform any demanding need and produce in excess of 650 W per Monoblock...oandbco.com
I still have the McCormack pre+power. It gets busy/muddy/shouty at moderate to high volumes and feels as if it is struggling for current.
I shall be using this in my bedroom setup with the old be718 now. It never felt like this with the be718.
Little bit off topic from the main discussion
But regarding your McCormack, if i am not wrong it would be 15+ years old ?
Might be even limitations with amp power but even the power supply capacitor would be past their age and hence bass would be muddier then what it was when new.
