A entry level AVR models of Onkyo, Pioneer and Yamaha would be available at that price provided your luck holds...you need to check the best rate and warranty options available with dealers....
The key is to understand what are your requirements in terms of connectivity/features and power output.....you may want to increase your budget slightly then.....
Please audition as many models as possible to take the correct decision...all the best..
