Back up softwares
subhash
bangalore
wanted to know good back up softwares for backing up m2ts files on to HDD
and experiences with different softwares(good / bad),
and also update on updates of newer versions and softwares
presently using Dvd Fab 8 HD (available free) which till now did a fabulous job in decrypting and also allowed to select audio tracks and remove all unwanted extra's ,the best option here is the option of selecting main file
with newer discs i suppose there's a variant in the AASC protection the Dvdfab 8 failed (SALT ,DISTRICT 9) but then it was backed up in no time with ANYDVDHD (also available as a trail version for limited period of 21 days) running at the background of dvdfab8
Anydvdhd trail version failed for newly released Band Baja Bhaarath
any other soft ware out there ?
Hi Subhash....are you ripping your BRs to M2TS format??? with M2TS or TS, you cannot have subtitle option...and are DTS HD and TrueHD quality preserved and intact?...btw...how close are you from realizing your HTPC dream? would like to know your plans?...sorry for the OT
yes direct to M2TS format as is from the disc
subtitle option very much possible in DVDfabHD
Selectable audio tracks and HD audio preserved 100:/: as is.
And selectable main movie file too
Not in to HTPC ,using the BDwriter only to back up on to External HDD and watch in HT set up thro Xtreamer (the M2ts format doesnt even play in my comp:D)
plan is to back up if liked , after watching thro rental
u will need to wait for new release...
nope IMO Anydvdhd is the latest and best out there ,this has never failed till date ,though have been using the free trail version
:clapping: to Band baja barath for incorporating a higher AACS protection
Has anybody purchased the full version of ANYDVDHD ??
its around 70euros (roughly 5k INR)
the trail version worked great at the background of DVDFabHD ,but with newer discs its tougher AACS:D
hehheh go for free life time updates EUR 110 :ohyeah:
are you using 6.7.8.0?
no its 6.7.7.0 version of AnydvdHD
is the 6.7.8.0 free trail or only for purchase?
are you using this??
