pavanai shavam ayi... hope you have heard this in a malayalam movie... lol
Translation please
so if i buy banana plugs from dac company ,i have to reconnect once a week right
please reply
ConnectorSupplier.com - Electrical Contact Resistance: Review of Elementary Concepts
this is an article which sheds some light on this pandora's box that manu4panjab opened![]()
Good quality (Gold plated) bananas always help
to the contrary-
"Contaminant films may also form by galvanic corrosion of the materials in contact. One of the well-known corrosion mechanisms is pore corrosion in gold-plated surfaces. As suggested by its name, this type of corrosion stems from the presence of tiny pores (usually sub-micron in dimensions) in the gold electroplate used as a finish on many connector surfaces. These pores allow access of corrosive environmental contaminants, such as hydrogen sulfide, sulfur dioxide and chlorides, along with moisture, to the nickel underplate or other substrate materials. Synergistic chemical reactions of the contact materials with the contaminants and water lead to the formation of solid corrosion products that creep out of the pores and spread along the contact surfaces. Examples of these corrosion blooms are shown in Figure 6 [4]. A striking example of the formation of copper sulfide corrosion products generated below a gold electroplate is shown in the cross-section of Figure 7 [5]. Pore corrosion blooms of the type illustrated in Figure 6 and give rise to increases in contact resistance of the magnitude illustrated in Figure 5, and cause severe contact degradation."
but most banana plugs you see are gold plated, does that mean we must now hunt for ones that are not?
i think it means -"buy the most expensive ones" - there are GP bananas which retail for $0.50 a pair, and others that cost $ 50 a pair. i suppose the costlier ones have a method of gold deposition that is nearer perfection (read lack of pores) than the less expensive ones (read S.E. Asian and MX)
bah, i'll stick with bare wire and save the cash![]()
I could not digest all the macroscopic mumbo-jumbo about contact points and corrosion completely ... What about pure copper spades that are not plated? If I silver solder the wire to them ...? Please spare a thought for them ....
Edit: I mean will a-spots get degraded if corrosion and inferior quality plating is absent? Oxidation can be fixed with brasso periodically right?
TIA
TIA
What about silver solder the wire endings and use without any plugs?
Hi cranky, the cable expert Van Den Hul recommends his own product "Solution"(by thin coating for the metal contact treatment&protection for audio video interconnects&for speaker cable)and I am using the same oil and my system sounds nothing wrong.You may check his article in Van den Hul: New Products. regarding the treatment for cable &connectors. But we should never use grease,vaseline like lubes. Since the 'Solution' is much expensive (30 ml. Rs.1800/),we can apply a thin, water like viscosity of 3 in 1 oil , as film coated.Spades do *not* need tightening. Both spades and ring connectors are extensively used in high power electrical transmission systems, that need many times the capacity and reliability of a consumer audio system.
If you have had to tighten spades often personally, you have either not done it properly the first time, or (more likely) your binding post does not have the capability of gripping spades with sufficient tension. Spades when properly secured are a lifetime connection. Using spades is illegal in many countries because it's very difficult to properly insulate, and the EU forbids use of any exposed electrical connection, regardless of voltage or current.
Are you suggesting that we put machine oil or other liquids on our wire ends before securing on to a post? And you really believe that advice is safe and effective? Liquids conduct much less efficiently than metal, as you probably know. I am sure you are enjoying your system with any method you may choose to, but I'm not sure it is advice that should be passed around.
Have a nice day![]()
Bare wire oxidises and loses contact, and poor quality bananas work loose with time. Use single piece bananas (not the ones with the leaf spring contacts on the end) or an expanding type for best long-term fit. Spades offer the best electrical connection and are totally gas-tight, I would use them where long-term stability is a concern. Speaker pins also work very well when used in the slot where bare wire would go.
Crimped connections are better than solder, but normally speaker cables have a large number of very thin strands so crimping may damage the wire and cause loose contact over time. I just prefer solder.
Bare wire should be used only when there is no option of using bananas (solid center posts) and quality spades are not available. Be sure to tighten connections once a few months, and clean off the the wire ends when doing this.
This is not about sound quality (not directly) you are looking at a connection that is airtight and stays locked down. If you don't plan to move your speakers around or change connections very often, bare wire will work fine as long as your binding post ensures it does not work loose. Most posts I've seen require retightening, and oxidise the wire even at the contact point (=not gas-tight).
regards.
I have been using isopropyl alcohol to clean all binding posts and plugs every year during Ayudha Puja day. It has kept thing clean and tidy fo r > 10 yrs.
