Batery powered DIY CNC phono stage
Brilliant use of the pen stand: it looks like something manufactured to spec, absolutely professional!
Here's an idea to keep the dust off the board, though it would impact the looks a bit: turn it upside down! You could put a layer of film over the back of the board to stop dust landing there affecting it. Then, for public viewing sessions, just turn it over :)
Re: Battery powered DIY CNC phono stage
That is better idea Thad.
Reuben, you can use transperancy sheet for covering inside. It is available at ?5.0 locally here. It will protect from dust and also let some air ventilation if you leave some holes open. Also serve your purpose of letting see inside.
Yesterday, Wify sat down with listening to some vinyls using the CNC phonostage and commented that the sound was slightly (marginally) dull when compared to vinyl played through the NAD 106. This was an interesting comment from a neutral observer who knows little about what's inside the equipment but who is extremely familiar with the sounds of the different equipment. I thought I'll fiddle around with the jumper settings in her presence and check on what sounded the best to her ears. The source was my SL3200 running on its usual M44-5. Started with the 18k jumper and she said it sounded very dull, as we moved across the jumpers from 33k to 47k she said that it brightened up as we reached 62k, she said that it sounded the most lively. We tried some combos, 18k in parallel with 33k and then with 47k and similar other combinations, all of which she rejected saying it was sounding "boring". Finally, just for the sake of argument, I removed all the jumpers and left all 4 resistors open. She jumped up and said that this is what she was trying to hear, it sounded very bright and chrisp. Interestingly the bass had not dropped and the phonostage was sounding very lively. I did notice that the ticks and pops were enhanced a bit but nevertheless she started enjoying the music and actually ended up sitting throught 2 Eagles records (Hotel California and One of these Nights). I did notice that these loading resistors roll off the highs to a certain extent. Any comments or suggestions?
Hi Sachin,
I'd like to purchase your DIY phonostage. Can get in touch and check out a few details about your DIY phonostage? Can you pls send me your contacts so that I can call you? Thanks much.
VinylShakti
My heartfelt appreciation for Sachin and Raghu for the CNC phonostage that is now at my audio racks. I have hooked it to my Sansui AuD7+ Technics 1200+Shure M97Xe combo.
Love at first sight (read listen) is an understatement. I was under the impression all my integrated amp phono stage can handle the phono reception very well. I am changing my belief. What a sound impression - Just love it.
Thanks to Sachin, Raghu and Bhaskar - I am complete noob to make this happen.
Honestly, a huge round of applause for Sachin and Raghu. I think the CNC is one of the best things that have happened to Vinyl lovers here on this forum and not to forget that very affordable price point.
+1 agree 100%, after building an absolutely maverick version of it, I have realized how good it actually is. Now I am setting out to build the actual version which Sachin is passionately advocating. I am 100% sure that this actual version will surely be the better one. This will be used by my brother with his NAD C320 and my SL3200.
Both CNC and HQMC Phono stages are great blessings for the audio community, looking at the cost involved nobody would believe that they could beat most the photo stages costing may be 5-20 times or more, until they listen to them.
Its not that you 'can try' them as they cost less and even if you don't like them you wouldn't loose much. They are in a different league altogether.
-sann'
Few days back I got two capacitors 1 uF / 250 Volts MPGP.
"P" stands for precise.
MPGP are supposed to be very nice and rare. These caps are PIO Polystrine with .1% tolerance.The problem is their size. I tried it today with some adjustments. I liked it as soon as stylus hit the record,highs are cleaner than before without compromising the bass.
Going by their size, I guess fully break in will take min 200 hrs:D
Sachin
Hi Sachin
When I first saw the pictures I thought its some new battery you have connected to the phono. After reading I realized they are capacitors
Indeed, these are really huge
From where did you get them?
Capzilla!
Switch off mains to CNC while playing and time how long it plays. I'm guessing it will play a long time as it will be storing lots of energy.
Capzilla!
Are these coupled with the output rails or are they used as power filters? You will experience retention only if these are used as filters.
