Link to information about the Diamond Cascode, a Diamond-like Buffer/Current Booster:
Diamond Cascode, a Diamond-like buffer/current booster - diyAudio
The first implementation (the LF07 v1.0) is a current booster for SOIC-8 opamps, in a DIP-8 form-factor. It's already been tested with an LM318M in a MyRef Rev C.
The AD797 already has a diamond-buffer as its output stage, so there isn't likely to be much benefit from using a SOIC-8 AD797 with the LF07 - but just about any other SOIC-8 *single* opamp, like the TL071, NE5534, LF356, OPA604, OPA627, OPA827, LME49710, LME49990, ADA4627, etc.,  should work seamlessly on the LF07.
In all cases, it should improve the sonics of the base opamp significantly due to the Class-A output-stage biasing, and near constant-current (typically 0.5 to 2 mA) output-stage biasing for the opamp itself. It also has no current limiting circuitry, so it could be used in a low-power headphone amp like a CMoy or similar, for better output-stage sonics.
If there's any interest in beta-testing these modules, PM me or email me at siva dot chander at gmail dot com.
