PS42A410C1 plasma TV - television SAMSUNG
PS42A450P1 plasma TV - television SAMSUNG
I picked up the info here.
Reign: Which Panasonic did you audition?
The Panasonic 42 TH PV80 is available now for Rs 60-65k and the 42 TH PV8 is available for around Rs 4-5k less.
Even in Bangalore the price is 60k for PV8 and 65 for PV80
hey anurag, how do you check that (the signal strength and quality)? With regard to the drop in the parameters, I would suggest you call the Tata Sky helpline, they are generally very helpful and guide you through whatever you need. But ya, on a 42 inch plasma the Tata Sky is only going to look reasonable.....firstly it's 4:3 and unless you want to watch it with bars on the side, you'll have to stretch it.....and secondly it's an SD image over a composite cable....in addition to that if there are signal strength issues, then this problem would be compounded.....although one quick tip to improve your Tata Sky picture would be to reduce the contrast a bit on the default setting for your composite input....
Will the "big tv" by relience be any better than the tata sky ? They claim mpeg4 transmission. The signals we have is SD. So how will mpeg4 make a difference ?
