reignofchaos
See if you can audition an ATC SCM7 or SCM11. One or two tiers above compared to all your options in transparency
Have you tried anything to arrest the brightness of your QAs? Like changing speaker cable, rca cable, dac or even your amp? Marantz are known for their thick sound with lesser sharpness, which you already feel bright, so one other brand you can try is an old NAD like a C320 bee. Sometimes slight modifications in your existing chain will help you achieve your desired sound.And the QA 5020 is on another level with imaging, resolution, transperency and clarity. When positioned correctly they just disappear and can put you in a trans. They are that good. But the only problem is they are bit too bright/ harsh. If it were only a little more mellow I would consider this as the end game for me.
I have turned down the treble on the amp and that has solved some of the problem. As you said my marantz is warm and smooth with other speakers so it's not the amp. I am not using rca as I only stream. So what speaker cables can I use to eliminate the brightness in the sound?Have you tried anything to arrest the brightness of your QAs? Like changing speaker cable, rca cable, dac or even your amp? Marantz are known for their thick sound with lesser sharpness, which you already feel bright, so one other brand you can try is an old NAD like a C320 bee. Sometimes slight modifications in your existing chain will help you achieve your desired sound.
HiName some of the best we can find in the market under 1 lac. Also mention the sound signature of the speakers if possible.
Based on my experience of listening and whatever I gathered from internet,
Elac b5.2
Q acoustics 3020
Kef q150
Polk R100
B&W 607 S3
Elac unifi 2.0 ub52
Q acoustics 5020
Quad S2
Wharfdale Evo 4.2
Polk Audio L100
Q acoustics concept 30
Yikes, I've seldom come across a speaker sounding bright with Marantz.I have turned down the treble on the amp and that has solved some of the problem. As you said my marantz is warm and smooth with other speakers so it's not the amp. I am not using rca as I only stream. So what speaker cables can I use to eliminate the brightness in the sound?
Probably a thick curtain in the room, and thick rug on the floor would do it.Have you tried anything to arrest the brightness of your QAs? Like changing speaker cable, rca cable, dac or even your amp? Marantz are known for their thick sound with lesser sharpness, which you already feel bright, so one other brand you can try is an old NAD like a C320 bee. Sometimes slight modifications in your existing chain will help you achieve your desired sound.
Did you listen to the Epos es14n’s ? Thought there was no dealer in India.Do audition Triangle speaker at Audio Planet Bengaluru - near to your place too. You will love the sound.
I listen to EPOS, Q Acoustics and Triangle and love 'em .
Second this for Faber. Sonus Faber Lumina 2 bookshelf is one of the sweetest sounding bookshelf that I've heard.Hi
You can check sonus Faber or xtz. Both are good and matching with marantz
PMC prices in India are not good. No chance of even the basic bookshelf within one lac.Heard PMC launched a budget range recently. Might want to check them out too
Transmission line and tunnel speakers are quite expensive in IndiaPMC prices in India are not good. No chance of even the basic bookshelf within one lac.
Epos has owned by Fink consulting now. And they have only one model. I had a chance to listen to it and wished it was available everywhere as to me it’s a perfect speaker in many ways at its price class. But I never thought this would come to India as it’s not even having many dealers even in Europe.I have EPOS M12i since last many years and the best match with my Pass F5. Balanced and musical . However have no idea on ES14N. I think Hifimart used to keep EPOS speakers, you may want to check
I have paired it with Cyrus6dacThis is one hell of speakers if paired with right amp.
Where did you buy it from and how much?I have decided to buy Elac UBR62 which I reckon is the improved version of UB52.
I basically need a speaker that sounds rich, smooth and natural. If you guys think there is anything better please suggest.
