Will a DVD player brought from Singapore work in India ? ( Any supply switchover issue or anything ?)
Singapore has the same voltage as India, and you will have no issues.
Any issues with bringing a pionner DV-610AV-S from US ( in case I can't get one from singapore ) ?
I couldn't find it's price in US :sad:
The Oppo 980H operates from 100 to 240 volts. In addition, there is a simple way to make it region free. If you can afford 9.5K, believe me, that is the best DVD Player for both movies and music in it's price class. I use it's elder brother, the 983, everyday as a CD Player to just listen to music. It comes very close to dedicated CD players.
agree fully. Been using the 983 for a year and no issues with voltage. And it's very good with music as venkat says. Highly recommend the 980 for music too.
Can you compare 983 with CDp(budget)?
What about pioneer 610? It is bit less pricey than dv99/oppo. It also plays SACD and DVD-Audio.
Is it this questions Spiro? - Can you compare 983 with CDp(budget)?
If so just wait for a little while. I have been auditioning the 983 as a pure CD Player. I shall upload the write-up by end of this week.
