Best Music Player
SanjeevM
Bhopal
I have been using VLC media player on Windows. Recently I tried the Groove player on Windows 10 which gave the best sound so far.
Can the FMs suggest which player gives the best sound quality on Windows, and whether the quality of sound is better from Android based players.
On windows I use Foobar and Pot Player and have been quite happy with them.
MaSh
FOOBAR IS GOOD ONE. but you need to learn on how to use it.you can customise it according to your needs.sky is limit as far as cusomisation is concerned.
If you want a paid software,then consider J RIVER
I use Mediamonkey - no one here uses it?
I have not noticed any realy difference in sound quality between players on my dekstop connected to my Dell speakers.
mediamonkey is goodone.but I too never noticed any improvement in audio quality.
BUT using FOOBAR I noticed lot of improvement when connected to
schiit modi DAC by tweaking settings .
I reckon it depends on the codec used.....
I use WMP9,Realplayer 8+ and VLC 0.7 and I think they all sound good. (Well as good as digital can sound which isnt very)
I am using Foobar 2000 with Wasapi from many years. I had settled with Foobar after trying JRiver, which sound like some DSPs running in the background and colored sound. Foobar 2000 is very natural and neutral, provides uncolored sound. Using this player with good DAC is just different level. VLC, Winamp, Window Media Player kind of applications are just average sounding players.
When compared foobar with Bughead player,later was impressive and much better than foobar.
Also some other players like Cplay,Lilith sounds promissing.
Swaroop, thanks for the input. Im also using vox but i find not so detailed comparing to vlc.
Sent from my Moto G (4) using Tapatalk
I definitely find it better than vlc on AB comparison. But surely Foobar and Bughead on windows are better. So checking if there is an alternative that is better.
