I'm wondering if I go the powered route, what would be best, competitively priced speakers in that price range available in India/Kolkata, and would it give as much bang for buck as passives with amp? Please suggest brands/models.
But why spend on active speakers when you have good budget ?
Do you mean to say actives are meant for low budgets below 35k?
... rather than Active speakers as it would block his upgrade path...
The upgrade path is never blocked! There are always going to be better active speakers hyeah:
Today, 35k, next year, 60k, after that 1 lakh, the 3.5 lakh... No end to the "upgrade" path.
Although, I have long been thinking that, for nearly 1 Lakh for a pair of small actives, I could get speakers for life. With speakers for life, who needs an upgrade path?
More seriously, I see there can be a perceived lack of flexibility with actives. I also see that the buyer cannot list out his amp, cables, speakers, and claim the credit for the "synergy" that he has achieved. But it is simply moving that process upstream to an engineer who has exactly matched the components. On the one side, the buyer misses some experience and fun, and on the other, the result could be superior.
It's a case of choosing one's path...
Hmmm.... I understand that Active speakers outperfom the passive speakers for the same budget (or) many times the budget.....
But these Audio Engine A5 is a powered speaker... I think they dont have active crossover which is the highlight of Active speaker....
So A5 is essentially an powered speaker with a passive crossover...
True. But the fact remains it will be very difficult to find separates within 35k which will sound better than the AE5. at that budget you can't buy anything apart from a norge amp, leaving very little for the speaker. unless of course you go for a tripath amp. But that'll have it's own set of issues.
So, I want to know - I don't want to be restricted to a nearfield setup, and I want my music to sound loud and good to fill a small hallroom and me sitting at the opposite end also. So where should I look for active speakers that are not nearfield speakers?
You can check out the KRK Rokit series, I had a quote for the stock available from the distributor, listed below
KRK RP 5 G2 - Rs. 24,000 pair Black - Rs. 26,000 pair White
KRK VXT 4 Rs.49,000pair
KRK VXT 8 Rs.90,000pair
KRK RP 10-3 Rs.90,000 pair.
dealer representative mail id : [email protected]
the price quoted was in the month of Dec '13, I don't know if they have changed prices, please enquire
Can someone help me make up my mind, after reading that Aktimate Minis are very good value and they sound better than more expensive speakers, I'm considering them. I want to know if they sound better than Q Acoustics' Concept 20 passives? Can anyone tell me what is the rate for the Aktimate Mini+? Are they within my budget? And where can I get them? They would have to ship to Kolkata.
