Best room correction system for my set up
Venkyrenga
Chennai
I have a wharfedale Denton 85 driven by Audiolab 6000a in a 11*12 ft room which is moderately treated. I also have Wiim pro streamer and Dacmagic 200M. Now I am thinking of adding a room correction system to the set up.
I don't have any clarity in this matter. So can you guys suggest me a good system. The only option I see is minidsp but not sure which model to choose.
Hi :)
I've played with a lot of DSP's, not everyone will like them. Depending on how acute your room issues are, you might like what they do. Especially when it comes to bass in small rooms, they work wonders. So before buying any box, I would suggest to try it for free and see.
I think Dirac gives a 3 days or one week free trail once you register on their site with your email ID. All you have to do, is borrow an Umik-1 microphone from someone on the forum. Then install the dirac live 2.0 software on your windows laptop, and then plug it up into your Dac magic 200M via usb and then measure your system and carry out Dirac correction, and see if you like it before committing to a purchase. All the best :)
Edit : Please take my opinions on DSP with a pinch of salt, as I've only tried the older versions. And the newer ones seem to be much improved.
