Best tv for 1.2 lakh budget.
Basically the title.
If picture quality is paramount, LG C3 or C3x, 55 inch with some good discounts will fit your budget.
If big scale viewing is a priority and you can be okay with a slight sacrifice in terms of picture quality, MI/VU master series 75 inches will be a good option and fits your budget.
