Hi forum members!!!
I'm planning to purchase a pair of bookshelf speakers to go with Marantz PM 5005 amp (Their entry level amp - If there are any better amp in this price range (22K) please suggest!!).
I had a demo of Polk Audio S20, which sounded great to me. I haven't been able to get a demo of Wharfedale Diamond 220 yet so cant comment on them. But while going through other speaker options in this price range i found a pair of speakers from Q acoustics 3020, ELAC Debut B5 and Dali Spektor 1( I have got a demo, but they are not as punchy and tight as the Polk one's IMO)as well.
I maybe able to have a demo of Q acoustics and ELAC.
Kidnly suggest which one of them would be better??
Suggest any other options if available in the price range of 20-25k.
P.S. I dont plan to add a sub.
My room size is around 130 Sqft.
Polks are v good for HT applications, not for 2ch stereo. WD 220s are v good for 2ch stereo, but are not all rounders and can sound dull in certain types of music, and also being warm will not be a match for Marantz as Marantz itself is warm and the combo can sound dull. Q acoustics 3020 are v good speakers and are very refined, but lack bass and will require the assitance of a sub, which in itself is very difficult to integrate to the fronts. Elacs are not that good and have low sensitivity, hence more power will be required from the amp. Dalis are good but can sound harsh at times. Bostons can get boomy and are not that refined as the Q accoustics, and can sound somewhat unnatural.
Of all of the above, WD220s are the best, balanced in every aspect, but the only problem is they are not all rounders and being warm, will not pair well with Marantz.
So what to do ? I would suggest the following.
1. Don't fall into the trap of marketing hypes.
2. You can choose either of Norge 1000 Gold or 2060, simple zero problem amps. Excellent support from company and if required, can also be repaired locally. With them pair the Norge Millenium speakers, not Ultimo.
Norge 1000 is around 80 watts rms at 1khz, which will be around 60 watts rms in the entire frequency range of 20hz to 20khz.
Norge 2060 is around 60 watts rms at 1khz, which will be around 45 watts rms in the entire frequency range of 20hz to 20khz.
3. If you opt for Marantz PM5005, then pair them with Sonodyne bookshelf 3260. Or else with Taga B40. For a secondary small speaker I could have also suggested Taga Platinum One, but not for primary.
